My RV-10
Date:  3-7-2010
Manual Reference:  Sec 7-7 DWG 16A
Brief Description:  Fitted / Sealed Outer Rib
Installed T-410 re-inforcement plate.
Sealed the tooling holes.
FItted / Sealed the outer rib
Installed the outer fuel capacitance fuel sender plate.
Installed fuel tank vent line.
Installed the 18 AWG wire through the gromments, for what I believe will be the last time.
I probably over did it on the sealer... but as we use to say in the airlines, a little more is better than not enough. We will see. I hope to have the right fuel tank complete this week. wish me luck.
Outer Rib Installed
Outer Rib Installed
Out Capacitance Plate
