Brief Description: Priming the Left Elevator Skin and Parts
Cleaned all the associated parts with the Left Elevator skins. The stiffeners and Trim components were etched and alodined.
Primed the inner skin with SEM self-etching primer followed by PPG epoxy primer reduced to act as sealer to help protect from corision. Same technique that has been used through the entire build.
Epoxy primed / sealed the associated parts for the trim motor, and elevator trim tab.
