My RV-10
Date:  7-9-2012
Number of Hours:  4.50
Manual Reference:  Sec 8
Brief Description:  Rudder
Worked on the rudder caps today.
Cut and fit the bottom of the rudder, lines up really nice, drilled a few of the mounting holes.
I fashioned a tool for the rod end bearings and adjusted as stated in the plans.
torgued the jam nuts and mounted the rudder with bolts to checked the rudder travel, stop to stop.
Strung the rudder cables and checked clearances to the rudder stops, all looks good.
Bottom Rudder Cap
Bottom Rudder Cap
Rudder Alignment / Stops
Rudder Mounted
Rudder Mounted
