My RV-7A
Date:  7-9-2009
Brief Description:  Cleaned and primed the inside HS skins
I scuffed cleaned the inside HS skins with Dawn soap and scotchbrite pad.
Just enough to remove the shine and make the water rinse sheet off clean and nice.
I then applied 2 light coats of self-etching primer, Followed in time by 2 light (wet coats) of PPG epoxy primer. This should give us the added corrosion protection needed here in Florida.
I also decided to... (I do not claim to be a riveting guru) go with the optional MK-319-BS Cherry Max rivets on the underside of HS-707... My Reasoning is... I went through all this trouble to prime these skins, the last thing I want to do is scratch it all off.
For the most part these rivets are more than sufficient to do the job.
All Primed Up
All Primed Up
HS inside skin
HS inside skin
