Fit the left wingtip clear cover... Trimmed and shaped as required. Installed 10 nutplates for mounting and test fit. Adjusted the landing light. Tested the lights... all functioning normally.
Mounted the Transponder tray, Mounted the ADHARS unit on the Avionics Tray. Installed the tray in the aft section behind the baggage compartment.
