Mounted the flap by removing a couple of hinge eyes at the mid point and inserting the pins. Secured the pins with safety wire, I may use a fiber block and bolt for final assembly. Drilled / Filed the hole in the fuselage for the flap push rod. Installed and adjusted the push rod. Electrically connect the flap switch / motor and position sensor to the VP-X and began to check functionality. Taped a digital level to the flap and zero'd it out. Adjusted flap position at 10, 22.5, and 35 degrees for testing purposes.
