Began sorting out the aileron parts... Installed the left mounts to the hinge points with proper washers / bushings etc. Fitted the left aileron, and cleco'd to the left wing to check clearances etc.
I wanted to see how everything fit... The only issue I see is the outed hinge is not exactly perpendicular, although clearances are fine and the aileron moves smoothly... Does not seem to be an issue, but I will need to do a little research...
