As I proceeded to finsh priming the right wong ribs, my paint gun for priming decided to blow a seal. I took the gun apart, cleaned and found that the only rubber part in the whole gun was ripped and un-usable. The only cost about $9 at hardbor freight, so not a huge issue.
I proceeded to prime the rest of the ribs using my larger paint gun, and all was well.
I put the right wing assembly together and made sure everything was in place and lined up. I again labeled each rib. This be as far as I go in the right wing for now. I will break it down and begin the left wing tasks. Srubbing, ech priming, followed by epoxy prime.
Hopefully it will not take me so long to get the left ribs primed up.
