Helper #1 and I headed out to the hanger early this morning... Our goal was to install the right wing... it took about 15 minutes to get it into place with the temporary pins... Greased up the close tolerence bolts, and tapped them into place. Installed the 2 AN4-13A bolts and torqued. The 4 bottom bolts are in place but will take some fancy wrench work to get them torqued. I will leave that until tomorrow.
I hooked up the autopilot to the right wing and had the skyview system discover the servo. Everything worked fine, I also was able to pull a GPS fix with the hanger doors open... it was nice to see the runway layout depicted.
