Drill mounting plate as required. Installed on engine, installed lower and upper cowling. Check alignment. Everything look really good.
Photo #2 shows the aluminum spacer, that slightly angles the airbox up. It also allows the mounting plate to clear the aft carb drain plug. No cutout relief is required. I have to adjust the carb heat control arm, it is making contact with the lower cowling.
