Installed the CamLocks on the lower aft cowl.. Installed the CamLocks on the front where the upper and lower cowling meet near the spinner. Installed the nose wheel faring, cut to length, and riveted the hinge mounts in place. Cut / Bent the hinge pin as required. Installed the #8 platenuts wheel pant mounts, temporarily installed the nose wheel pant. The intial fitting is ok, but it is going to take a few more hours to get it perfect.
