Received my Electric Roll Trim Kit from Van's Today. Inventoried the kit, and reviewed the plans and documentation. Tested the trim motor on the test bench and located the center travel location. Modified the fiber block, and drilled the required mounting holes. Notched the block as specified for cotter pin. Trimmed the mounting bracket as required, and match drilled to the right floor panel.
