My RV-10
Date:  2-9-2013
Brief Description:  A/P Pitch Servo / BU Alt Wiring
I di not get much done this weekend... Feeling a bit lazy.
I did manage to re-installed the pitch servo and tested successfully.
Installed a 10ga wire for the BU Alt (FS1-14B)... It is still on backup order, but hope to take delievery in the next couple of weeks. I opted for the higher output the "B" has, due to the recommendation of Vertical Power. (VP-X Pro Manual) I wired a on/off/on switch for ALT 1 and ALT 2... seemed the simplest and most logical choice.
Upper Right Switch. ALT1 / ALT2
