My RV-10
Date:  11-25-2012
Number of Hours:  2.50
Manual Reference:  Sec 8
Brief Description:  Flaps
Mounted the flap by removing a couple of hinge eyes at the mid point and inserting the pins.
Secured the pins with safety wire, I may use a fiber block and bolt for final assembly.
Drilled / Filed the hole in the fuselage for the flap push rod.
Installed and adjusted the push rod.
Electrically connect the flap switch / motor and position sensor to the VP-X and began to check functionality.
Taped a digital level to the flap and zero'd it out.
Adjusted flap position at 10, 22.5, and 35 degrees for testing purposes.
Hinge Mount / Pins
Hinge Mount / Pins
Flap Full Down Position
Adjusting Flap Deflection
