My RV-10
Date:  11-11-2012
Number of Hours:  6.50
Brief Description:  Carb Air Intake Box
AirBox is a bigger job than I imagined... I logged about 12 hours over the last 2 days.
Fabricated the carb heat door, cut the airbox to shape. Installed the hinge / hinge arm.
Installed the carb heat cable, cut to length, and tested operation.
Installed the carb heat intake to crossover exhaust, and mounted the heat intake tube to airbox.
I need to get some 2" scat tubing to complete the assembly.
Cut the bottom of the air box for the alternate air intake, drilled / sealed and mounted the flange.
Fit the alt air door, installed the control cable in the cockpit, and cut to length.
Carb Heat Door
Carb Heat Door
Alt Air Intake
Alt Air Intake
"RED" Alt Air Control Cable
