I plan to install the fuel flow transducer after the electrical boost pump and before the engine driven pump. According to other builders this works fine. I will have to fine tune it as I fly through the test phase.
I continued to run wires for the EMAG-P, P-Lead, Power and Ground. I plan to have physical switches in the cockpit to cut aircraft power to the EMAG and test the internal alternator.
