Started the evening by fabricating mounting angles for the throttle quadrant. Adjusted the length, and test fit the throttle / mixture cables. Fabricated 2 angles for the Dynon EMS monitor. Routed the wiring for the engine sensors and MAP sensor.
I felt as if I was working backwards this evening, because my original thoughts of where I wanted to mount the EMS module just did not work, I ended up having to re-route a bunch of the wiring.
