I thought I would throw some photos in here this evening... I have been running wires and such, not all that photographic. Anyway, Installed the starter annunciator circuit this evening. Soldered the 1K ohm 1 Watt resistor inline with the J2-11 circuit on the VP-X Pro. Ran the wire through the firewall to starter side of the solenoid and powered up the VP-X. Engaged the starter, and as you can see in Photo #2 and #3 the starter annunciator indicated the starter was active.
