Not too much work to report this evening. I removed the oil cooler fittings (Alum) I was using to route the lines. I have everythnig the way I want, so I will be installing the fittings (Steel) for good. I went by the airport, but they did not have everything I needed in Steel, so I decided to add the oil / fuel fittings to my aircraft spruce order.
My back ordered fuel line from Van's cam in, routing the line was interesting, since I have the Vetter exhaust with mufflers it comes a bit close, about 1" clearance, I will put another layer of heat shielding and all should be just fine.
