Terminated the EGT / CHT wires for Cylinder #1 and #3, wrapped and secured. Trying to keep it simple, I am using insolated spade type connectors. I used a piece of #4 cable to measure the cable runs for the Throttle / Mixture. It looks like 48" quadrant cables offered from Van's should do the trick.
I already have the push pull cables for the Carb, Cabin Heat, and Oil Cooler vent.
