Received a shippment from Van's, included the fittings for the engine driven fuel pump. Installed the pump fittings, fuel lines, and fuel pressure fittings / lines.
Ran the 18 AWG starter wire from the VP-X Pro area, and wrapped it up. Fabricated 2 angles for the VP-X mounting plate. Temporarily installed the VP-X. Decided to install the VP-X just above the rudder pedals, offset to the right side of the fuselage.
