Fabricated the left and right brake lines. I cut (2) 40" piece of 1/4" aluminum tubing, flared and strung the lines per DWG C2. Hooked up and pulled a 20" vacuum for 30 minutes on the fuel lines all the way through the firewall. Both left and right lines... Everything is solid, no leaks.
