Completed riveting the firewall recess. Mixed up some proseal and sealed the edges of the recess. Drilled the access holes for the throttle, mixtue, carb heat, cabin heat, and fuel... Also drilled the hole for the nose wheel bolt. Installed the engine mount to check clearances, and alignment of the holes, all seems real nice. Installed the battery box to the firewall.
I am getting close to mounting the engine, I will be working on getting the fuselage on the wheels.
