Worked on the engine baffling and the airflow venting for the oil cooler. fitted and cut the access holes, drilled all the mounting holes. Positioned and drilled the airflow vent.
Every looks good, I have to clean up the edges and smooth things out. My oil cooler should be in this week, I will get everything ready for mounting.
