Brief Description: Vertical Power VP-X Pro Test Bench
After making up my mind on switches, and the layout... I found a laser engraving shop about 2 miles for the house, so when the time comes I will let them work their magic.
Continued to focus on my test bench for the VP-X Pro and associated circuits. Bought a 13.88 Volt 19 Amp power suppy from Radio Shack and mounted it to my bench. Mounted the VP-X Pro and installed a grounding strip.
Connected the PS with an inline 15amp fuse 12ga wire to the VP-X and pinned out one of the ground wires for the VP-X. (The VP-X has 2 redundant grounds)
Powered everything up, and verified everything was in order by hooking up my laptop... I should take deliver of my Master and Starter solenoids tomorrow. I plan on testing the flap system in a few days, since I have all required components.
