My RV-10
Date:  1-11-2012
Manual Reference:  Lyc. Maint. Manual
Brief Description:  Engine Assembly
Installed / Torgued the governor plate.
Installed / Torqued the oil sump.
Installed / Torqued the intake pipes.
It is starting to look like an actual engine, instead of a rack full of parts.
Hope to have the other two cylinders by Sun n Fun...
As you can see... I need a fuel pump, carb, starter, and some mags.
I will core trade my fuel pump.
Possibly rebuild my carb... or core trade.
Probably will go with a SkyTec starter.
I will go with (2) P-Emags.
I also plan to go with a Plane Power 30a backup alternator.
Governor Plate
Governor Plate
Oil Sump
Oil Sump
Intake Pipes
Intake Pipes
