My RV-10
Date:  10-22-2011
Number of Hours:  1.00
Manual Reference:  Lycoming
Brief Description:  Accessory Case
Installed "NEW" Oil Filter Adapter, gasket, sealed and torqued.
Installed "NEW" one piece Oil Pump Housing, impeller gears and Shaft. (P/N 05K19423-S)
Pre-lubed, Torgued to 150 in lbs, and safety wired in accordance with the following.
References:
Lycoming Direct Drive Overhaul Manual
60294-7 - Revision June 2002 7-10B
Service Instruction No. 1164B
Service Bulletin No. 524
FAA-H-8083-30 5-80
Oil Filter Adapter Installed
Oil Pump Installed
Oil Pump Installed
Assembly Products
Assembly Products
