My RV-10
Date:  9-13-2011
Manual Reference:  Sec 8 DWG 37
Brief Description:  Forward Fuselage / Rudder Pedals
Finished match drilling the forward bottom skin to the firwall.
Drilled the rudder pedal mounting blocks F-6116.
Measured the 3" from the firewall along the F-719 aux longerons.
Removed the F-719's and fitted the F-6116 blocks, and drilled the first set of mounting holes.
Measured 1-1/8" center to center... and I now have 6 holes. and 3 adjustment settings.
I am 6 ft tall, so I will probably have them adjusted to the middle position as pictured.
Mounted everything into the forward fuselage just to make sure everything lined up.
Rudder / Brake Assembly
Rudder / Brake Adjustment
