My RV-10
Date:  8-28-2011
Number of Hours:  4.00
Manual Reference:  Sec 8 DWG 23
Brief Description:  Forward Fuselage
Continued the fit lower longerons, drilled to WD-603...
Fitted F-902 to give everything a bit more stability.
Fabricated and fit the F-684L&R gusset.
Everything is fitting together just fine...
The only issue I have run into so far, I had to fabricate another F-684L due to edge distance.
It was my fault, since I did not check the alignment with the firewall before match drilling to the
F-713 Longerons. Anyway... I just made another one, and it fit nicely.
F-902 Fitted
F-902 Fitted
Lower Longeron to WD-603
F-684
F-684
