Big night in the shop... Match drilled the seat / baggage floor skins. Flipped everything over, adjusted the saw horses. Then to my surprise everything fit together perfectly. I had to go sit down and read to make sure I did everything right.
The Center and Aft fuselage slide right together, holes lined right up... began to cleco everything. I felt sure I was going to struggle with this fit... But. not at all.
Since I felt so good about it... I continued to fit the side skins... no problems there either. Everything fit nicely.
