My RV-10
Date:  5-31-2011
Number of Hours:  5.00
Manual Reference:  Sec 8 DWG 20
Brief Description:  Aft Bulkhead
Continued to work on the aft bulkhead.
Fitted / Match drilled the seatbelt mounting brackets.
Fitted / Match drilled the remaining bottom supports, after buying a new bandsaw blade, really made the job go fast, cut it easily and straight. Waited way too long to replace the blade.
Fabricated the seat adjustment angles / match drilled.
705 Bulkhead
705 Bulkhead
Seat Back Angles
Seat Back Angles
Seat Back Angles Gaps
