My RV-10
Date:  3-15-2011
Number of Hours:  1.50
Manual Reference:  Sec 7-9 DWG 13A
Brief Description:  Left Wing Pitot / AOA System
I have been thinking for the past few days about how I will securly guide the Pitot / AOA plumbing around the bell crank / control system.
I fabricated this guide bracket that will share the bell crank mounting hardware.
Simple but effective. It is fairly ridged and seems to work exactly the way I want.
I am going look around at other builder logs to see if there is a better way.
Update:
I was looking around at ideas on routing the Pitot/AOA through the bell crank area.
Some folks are actually routing it under the bell crank, not sure I like that to much.
Some are using ridged aluminum tubing from the Pilot/AOA through this area and then continuing through the rest of the wing with the flexible tubing, that I like... I am happy with what I have, so I will continue to invite ideas from my area builders...
Pitot / AOA Guide Bracket
Pitot / AOA
Pitot / AOA
