Brief Description: Riveting / Test Assembly Left Aileron
Mounted my brake assembly to the bench and formed the trailing edge. Turned out nice and straight and ture. Began test assembly of aileron ribs / spar / leading edge and counter weight. Final drilling / deburring / dimpling of bottom spar / skin to accomidate the CS4-4 rivets. Fitted and riveted the count balance weight to leading edge skin. Prep for the nut plate for the mounting assembly.
