My RV-10
RV-7A
Sec. 7-9 DWG 13A
Epoxy Primed / Sealed Rear Spar
Epoxy primed / Sealed the outer rear spar and hinge points.
My plan is epoxy seal any areas that will be exposed to the outer eliments.
I am using a 3 part PPG Epoxy primer... thinned to specs which acts to seal the structure.
Seems to work excellent... need a chisel to get it off.
Rear Spar Epoxy Sealed
Hinge Points Epoxy Sealed
RV-10 Home
RV-7A Home
2191
Cockpit
130
Elevators
199
Flight
Fuel Tanks
68
126
734
Hanger
Horizontal Stab
Introduction
Mistakes
Paint Schemes
Practice Kit
Shop
Vertical Stab
339
