Brief Description: Mark Fuselage and Wing Bolt Holes
I used the pattern I made of the wing profile to mark the left and right sides of the fuselage. Even though I marked numerous locations to assisting in locating in the correct position on the fuselage there still was a bit of estimating the correct location of the pattern. I feel I got them pretty close to where they need to be. The purpose of marking the fuse is to allow me to trim the intersection fairings so they are real close to where they need to be. I can always modify them a bit after the wings are actually on if need be.
I then spent the rest of the session working on removing paint from the wing bolt holes......which is a little slower process.....
