Been trying to catch up on some work that I have had around the shop for a couple months for a friend Jim. I had to order some things for my projec and waiting for them to arrivet so I felt this would be a good time to catch up on Izzybear's stuff.
I had made a fixture for machining the bellcranks for the upgraded Sky Designs bellcrank brackets. We had measured them when I was in DFW in January and I brought them home with me. I got them milled to the right dimensions and complete.
I also used the lathe to make a thin wall socket he needed and remove .050 from the cable B-nut that wouldn't fit a washer between the cotter pin.
Finally I made the cut in the left inlet ramp for the snorkle identical to mine. Ralph had put a cable end on his trim actuator.
