Bob's RV-8 Build Site
Date:  1-16-2022
Number of Hours:  3.30
Brief Description:  Wing Tips stiffiners and hinge blocks
With the wing tips curing in place on the wings for over a day I went out and removed the tips from the wings and cleaned them up and removed the peel ply. Everything really came out great and I am amazed how the thin foam strips and the fiberglass really worked fantastic for stiffinening the wingtip upper and lower surfaces!
Next I did a little more finish work on the hinge pin retainer blocks by rounding all the corners and remove the sharp edges. Other than sanding and filling and priming.....the tips are done.
Stiffiners curing in place
Finished wingtip hinge pin blocks
