Bob's RV-8 Build Site
Date:  1-15-2022
Number of Hours:  5.20
Brief Description:  Make and Install Lower Wing Tip Stiffiners
I decided that the bottom of the wingtips needed a little stiffining and decided just to do it (despite the fact that I really didn't feel like it haha).
So it was the same process.....band saw and sanding block helped me to form the rounded pieces of foam from the pink foam material I got from Rob and Rick years ago. Once again the foam cuts great with the bandsaw and then sanding. I decided that making the pieces the width of the foam panel which is 24" was sufficient length to stiffen the trailing portion of the wingtip where it flexed the most. I cut the strips just under 1/2 inch thick. On the lower stiffiners I decided to make the width of the strips 3/4 inches down from the approx. 1" thickness that the foam board comes in.
After cutting the strips out I then set up a 45 degree angle to run the foam along the edge to cut the corners off and make it easier to complete. Then I used a sanding block with some 220 grit sandpaper and took time to shape the surface rounded across the width and at the very ends tapered them for the last 2-3 inches to feather them into the wingtips.
I cut a single fiberglass strip for each stiffiner, mixed some micro and laid in the fillets and then covered the foam strips with the fiberglass and peel ply. I set them in place on the airplane to make sure they would form to the curvature while curing.
Fairly flimsy foam fabbed stiffiners
Stiffiners in place
Stiffiners in place
Another angle
Another angle
