I taped the right side down and Nancy helped hold in place until I could get the first 6 holes drilled using the strap duplicator--drilled them to a #40. Continued from the back toward the front drilling and clecoing until reaching the front of the skirt. Cut some of the back end off where it was overlapping the left side. I have a 12” strap duplicator and was able to use it on the vertical ribs. The last hole in the tube that connects to the rear bow is off just a bit. The 2 holes below this one were also off slightly, but they straightened out ok when I drilled up to 1/8”. Top hole—not sure about, may have to glass it and redrill. The right side bottom edge fits much better than the left side. One place has a slight gap, but the rest of the edge is flush on the fuse. Back end fits pretty well, but over the curve of the rear skin I have a 3/32” gap for about 16 inches. Gotta love these pink skirts!
