Steve & Nancy Riffe
Date:  4-12-2012
Number of Hours:  1.00
Brief Description:  Modify ADAHRS mount, prep tail cone for rivets
Picked up some JB Weld today. Mixed up a small batch and worked it under the little tabs on the F811 bulkhead. Then I clecoed it all together and will let it dry overnight. There was one tab that was not sticking up, so I grabbed the pneumatic squeezer and set a rivet in the hole-almost. It leaned over so I drilled it out and set another—success. After the ADAHRS mount discussion on VAF a few days ago, I decided to make provision for dual ADAHRS while I had good access to the area. I am planning on a single Skyview system, but will have the ability to add a second unit later. Used the template that I previously made to layout and drill holes in the longeron braces.
Tab in upper corner-JB Welded
Drilled angles for dual ADAHRS
