Brief Description: Finish Xponder wiring, started coax for ELT anten
Finished the transponder coax run and added a TNC connector to the end of the coax. Used some self fusing tape for strain relief on the cable/connector. Drilled a hole for a snap bushing to pass the snakeskin bundle thru the bulkhead heading toward the front. Next I made up the ELT cable—added a BNC connector to one end. Not sure what to put on the other end yet, but I’m thinking some sort of bulkhead connector—need more research on this.
