Received some “snakeskin” today, so I fed the ADAHRS wires thru, then passed the bundle thru a couple of bulkheads. I intend to follow the same path as the a/p servo wires. Will wait to secure them to the support ribs until I run the wire to the master relay—more wire on order. Other than the wiring to the ELT, I believe the wire for the master switch will finish up the wire runs in the rear deck area. The trim servo and tail light/strobe wiring will pass thru the corrugated conduit previously installed.
