Brief Description: Rudder-Finished Dimples, Shot Primer
Ground the nose of the yoke until I could get the dimple die to sit flush. Then dimpled the 704 rib, except for the last 2 holes on the top and bottom where the squeezer would not fit. To get those holes dimpled, I used a small steel plate and put a counter sunk hole at the edge. Used the male dimple die in the rivet gun to smack the rib a couple of times—worked quite well. Cleaned up all the small parts and rattle can primed them.
