Steve & Nancy Riffe
Date:  4-29-2016
Brief Description:  L. side bension rods installed
Went thru pretty much the same routine for the tension rods on the left side as previously done for the right. Lots of put them in place, remove, bend, re-install etc etc. I intended to slip some of the anti-chafe tubing over the outboard rod before I bend it, but somehow forgot. So, I slit it with the dremel, added to the rod and used some safety wire to secure, then a final install of the rod. Glad to be done with these little buggers! Next up is baffle seal material.
L. inboard tension rod
L. outboard tension rod
