I needed fiberglassing stuff. Turns out there is a large fiberglass supply company at Skagit airport. So $200 bucks later I had the stuff.
Rolling pizza (fabric) cutter Cutting mat made from grease board Resin, hardener, Measuring cups, brushes, scrapers Cloth, Plastic, Peel ply Micro ballons, Cotton Flock Black die, Sand paper
And I decided I needed more light from a high source so I put my flood lights on a cabinet. Now I can see.
I'm leaving the canopy on the fuselage for starters. I'll remove it when the heavy sanding begins.
I started by sanding the plexiglass with #80 sandpaper to remove all shinny areas.
