Can't procrastinate any longer on doing the fiberglassing fairing or fillet on the canopy.
Directions on resin say to mix 5:1 with hardener either by weight or volume. I decided to go by weight since I did that with the proseal.
First I put just a little black dye into the resin. Then I added flock until it was pretty thick, not runny. Then after I had the resin ready with dye and flock I added the hardener. I get about 15 minutes to apply this stuff.
Oh did I mention I'm using Epoxy resin, not polyester like in the Gold resin I bought earlier. Plans say don't use polyester resin.
