Brief Description: Flap Mechanism 10 Match drilling angles/ braces
I match drilled one of the previously made attach angles to the rear brace. I ensured it was 90 degress to floor and parallel to the brace. One hole was pre-drilled. The other hole is match drilled with the cargo floor center cover.
And the front brace is used to match drill the attach plate previously made with the bend in it.
