RV-7A Construction Log
RV-7A
Fuselage After Flip
12-1-2009
Flap Mechanism 9 Match drilling the doubler
Next the double plate for the actuator bolt gets match drilled to the brace. And the bolt hole gets enlarged to 1/4.
I used the 1/4 drill. I should have used the step drill because the step drill does a smoother job. The drill chattered in the hole.
Match drilling this doubler to brace
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
