RV-7A Construction Log
RV-7A
Fuselage After Flip
12-2-2009
Flap Mechanism 11 Installing Braces into Fuselage
Now it is time to install these braces and actuator into the fuselage and finish preparing the parts for final installation.
The front brace goes in and needs the top plate match drilled with the 705 bulkhead.
The rear brace goes in and also needs to be match drilled at the top with the 705, but not until I install the side covers.
Install braces into fuselage
Match drill plate with 705 bulkhead
Rear brace gets match drilled later
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
