Brief Description: Front Deck (Tip Up) 29: Air Inlet Vent
With the air inlet in position I made sure it was correctly positioned by drawing the centerline on the side brackets and looking for the line through the holes in the fuselage. There it is. Things seem to fit just fine.
So, I bolted the vent in position and drilled the bracket and clecoed it.
